SQ compressor bug
Hello
I’m using an SQ7 and I have upgraded the console to version 1.6 yesterday .
when sending an input signal to an AUX at POST FADER the compressor on the input channel doesn’t seem to change the signal.. gate and EQ are working just fine.
sending the same input signal to the main LR is working well, the compressor is affecting the signal.
Does anyone have the same issue ?
(resume -input channel compressor working normally on main LR but not working when sending the signal to an AUX at post fader)
Also , where can I find an older version of SQ mixpad for iOS in case I will downgrade the console ?
Thanks a lot
Solved by AH
Please navigate to your Aux’s Routing page and change the source point to Post Compressor.
This is done by pressing Routing> Select Aux > Press ‘Aux Snd’ icon > Select Channel Source and change to Post Compressor.
