In a single SQ Mixer can I split the mic/any input to two channel strips and have separate gain and EQ structure for FOH and Monitors?
You can use the same input on more than one channel but they all share the same gain. but every channel also have an individual digital trim which can be used to adjust the internal channel gain. The rest opf the hannel processing (Preamp, Gate EQ, Compressor and routing) is then individual for each channel which uses that single input.
you have 48 channel and you can assign one or more ip to one source.
but gain share.
Eq dyn and assign where you want.
Thank You for the information. it clears my query. Can anyone has documentation or video on this? It will help us to implement.
Thanks in Advance.
