SQ Drive file questions
I’m using a Samsung SSD for SQ Drive in multitrack mode (48kHz/32 channels), without apparent problem for recording or playback. By default, I patch all 32 tracks, so each recording has 32 .wav files associated with it.
Is it possible to manipulate this directory structure on a Windows PC to save space on the drive without formatting? i.e.
  • Can you rename each recording with a sensible name (e.g. a song title) ?
  • Can you delete a full recording (i.e. the directory including all 32 .wav files) ?
  • If there are unused tracks, can individual unused .wav files be deleted ? (Yes, I know they woudn’t be recorded if there wasn’t an I/O patch entry for them…) Does the desk software on replay use the available files to utilise the individual tracks?
  • If either or both the above work, can the Windows de-fragment tool be used on the drive to optimise the disk for subsequent recording?
I’m not in front of the desk at the minute, otherwise I would try some of these; also I have looked through the Support topics and this forum for answers to the above without success.
Chris
You can do all those things. Renaming files will make them invisible for SQ. Deleting files “empty” tracks is no problem. Deleting complete Record folders is also not a problem. Please do not defragment an SSD…
Best Regards,
Tobias
I just found this article on support about the directory structure and naming convention, which helps to answer the questions (and thanks Tobias!)
