SQ Drive MTK problems
I have just received my SQ6 and was really excited about loading some audio up through SQ drive in order to have a play around with it but alas this was not to be.
The WAV files used were direct from my QU desk and put into the correct SQ folders with the correct names and even converted to 96khz but when i select the folder on SQ drive, it does not allow me to press play.
anything recorded from the SQ desk will play back with no issues.
Please help
Hi Nemix,
If you are porting tracks from Qu to SQ, note that the multitrack folders must contain 18 tracks for Qu, but only 16 for SQ. This catches out a few people.
Also, since you applied sample rate conversion, there is a chance the DAW you used has saved the files in a slightly different format, for example with BWF chunks or a Waves64 header, thus rendering them incompatible with SQ. If using Reaper for example, make sure you are rendering to 96kHz 24bit mono files (24 bit PCM) and untick the Waves64 and BWF options. Finally, make sure all converted files are exactly of the same size.
Hope this helps.
