SQ Drive Settings
Hi all! First post on the forum after years of being an avid A&H user. I’m curious if there is a way to change the SQ Drive multitrack recording to be pre or post-processing? For example, if I am recording in a club with a bad PA, I wouldn’t want to print the EQs that are compensating for said PA on my tracks. On the flip side, if I were doing a quick recording session without my computer, I’d want to print all of the processing for sure.
I’d appreciate any help! Thanks! My SQ-6 gets here on Friday, but I would need to be able to access this feature (if it exists) right away and didn’t see anything in the manual.
Jordan T. Hurt
FOH Engineer (Alice Cooper, CO-OP, Flaw)
directionofcreation.com
I believe that the SQ Drive recordings are affected by the Direct Out settings. See pg. 31 of the latest SQ Reference Guide. In those settings you can select where the tap point will be in the signal chain of the input channels.
If I am incorrect I’m sure someone on this forum will correct me.
