Hi, as I often record our shows using my iPad, it would be great to have a visual response when the SQDrive record & playback commands are activated via Mixpad’s soft keys. Presently, the command is (hopefully) transmitted without any confirmation it is being sent. A simple red light or alike would suffice…
Txs.
@Lozion
What app do you use to record to your iPad?
Is that through USB B or?
Where do/would you take the feed from your desk?
Regards.
NZdave
Hi NZdave, we use the internal SQdrive to a SSD USB hard disk enclosure and also playback tracks from it. The iPad is simply used as a record and playback device via the user defined soft keys.
Sorry if it was not clear…
