SQ Firmware V1.2 Released
You can find it here
There’s also an IOS update for your iPads for firmware 1.2.
Thanks Art! This is great!
I’m hoping this release is stable. (I’m relatively sure it is given A&H seems to give their test team plenty of time to do testing).
I’ma test it tonight/tomorrow before a gig this weekend just to make sure. Though it’s not the same as I’ll be using the USB driver instead of local or digital snake…
-Nathan
The three seconds audio loss in the middle of the show is solved?
Richard
V1.2.0
Additional Features:
D-Classic Automatic Mic Mixing added. Support for DX-Hub.
‘Chorus’ and ‘Noo Phaser’ FX units added. Assignable Channel Colours.
Factory Processing Libraries added.
Input to PAFL source point selection added.
Improvements:
ID-839: Fix UDP port numbers to allow port forwarding.
ID-784: Match Frequency and Width values on PEQ screen to hardware.
ID-739: Add categories to FX Library.
ID-447: Enable selection of ‘Processing’ or ‘Routing’ screen key before selecting channel.
Issues fixed:
ID-852: Channel settings recalled incorrectly when changing channel stereo status ID-812: Stereo width changes can cause issues when switching channels back to mono ID-804: AR/AB units can dropout or enter update mode
ID-803: Static IP settings not updating correctly
ID-723: Changing gate sidechain source from ‘self’ on SLink input channel mutes audio ID-726: Selecting PAFL on SQ-MixPad changes ‘Sel’ on surface
ID-721: ‘PAFL Follow Mix’ does not work in ‘Fader Flip’ mode
ID-468: Master fader does not update when level changed on SoftRotary
ID-437: Next scene does not update after scene name change
ID-634: Surface can freeze with bad connection to SQ-MixPad app
