Sq Login issues
Hello Community,
wàWhen I power up my Sq, the touch screen does not work, so I can not Login. I must switch off the console et switch it on again. Then it works. But it stress me out, that maybe one day I can not Login and not able to use the console. Have you heard about that ? Thank you very much.
That ist a Problem with older Firmware. Update and all will be good.
Best Regards,
Tobias
I also had that issue just two days ago running firmware v1.4.4 on SQ5. The only thing that I did differently versus every other time I powered up was I had a formatted USB stick inserted.
It’s strange that you and I both just had this occur. I’ve had the SQ for about 5 months and have run 20+ shows with it….as well numerous boots/reboots learning the features.
Looking at the v1.5.9 release notes, this bug is specifically addressed.
Thank you very much guys !
Indeed, I updated to 1.5.9
So far so good.
