We have upgraded to an SQ6 from a QU16 this year.
After following the video on how to set up the two consoles to talk to each other I can get audio from the qu to pass to the SQ (on the slink channels 21+)
But the QU doesn’t seem to be able to receive any audio from the SQ. On the Qu it says “dsnake not connected”
As far as im aware ive followed all the right steps but wondered if i was missing something. Or if this option is not possible?
i’d like to use the qu for a livestream mix if at all possible rather than going down the dante route if i can.
Any advice would be very helpful on what i might be doing wrong.
The Qu was only ever intended to work with a connection to a remote audio unit and not another system, therefore, although we were able to allow the SQ to ‘discover’ a Qu, the Qu cannot discover (see) the SQ.
If you have followed the video and patching information here - https://support.allen-heath.com/Knowledgebase/Article/View/1188 - and ensured you have sync’d the SQ to the Qu however, then you should be good to go.
The Qu will show ‘N/C’ for it’s dSnake inputs, but if you send audio from the SQ (using the SigGen for example), you should find it appears at the Qu.
i just did a re install of the latest firmware and it seems to have burst into life and work like you have explained. I get why it says “N/C” now too thanks for clearing that up.
