Hi All,
SQ V1.5.4 is now available to download ![]()
You can grab it here - https://www.allen-heath.com/key-series/sq/sq-software/
Cheers!
Hi All,
Cheers!
Going to be an upgrade party then on Saturday with Windows 21H1 out and OBS 27.0 just released too ?
cĂł gĂŹ hay khĂ´ng nháť
I see thereâs some changes to AMM metering. Thatâs great news! Hoping it fixes the PAFL/AMM issues also. I wonât be at the desk for at least a few days but very keen to try it out ![]()
as far as I remember there were no issues with PAFL⌠there were only wrong expectations⌠![]()
last time I did a job with a SQ the PAFL worked as expected to me, only the metering was misleading
Of course there are issues Steffan, the same issues that were present and have been fixed on dLive if I remember correctly. But I understand from almost every previous post of yours that you just like to be obtuse and argumentative, so Iâll just leave it to you to continue doing that. Have a great day.
Which? I donât remember them⌠it was 2 months ago, as I used the SQ with AMM
could reproduce the metering issue
found the old thread
https://community.allen-heath.com/forums/topic/pfl-and-amm-signal-flow-issues
I couldnât reproduce your issue with the PAFLâŚ
I could PFL channels assigned to AMM even if they are mutedâŚ
I remember failed to reproduce your problem on the last gig I had
but could reproduce the issue with the AMM meteringâŚ
maybe @Keithjah could chime in here�
Sure! - V1.5.4 is a maintenance release. Along with bug fixes, these can include improvements, but do not add features and very rarely make any fundamental changes to the core.
As @SteffenR pointed out, the position of the AMM gain stage (which Iâm pretty sure is whatâs being referred to here) would not be classed as a bug/issue which needs to be fixed because itâs currently working as intended.
The discussion in that linked thread is about whether it would be better in a different position, and if that were deemed so, it would require changes to the core architecture and quite a lot of development/testing time.
@steffenr to reproduce what Iâm discussing simply add some mics to AMM and have their faders up so the AMM is actively affecting them. Then PFL a channel which is also in the AMM but is muted or has its fader down⌠You will hear nothing because the AMM has silenced that channel (doing itâs job) and the PFL sits after the AMM in the signal chain.
Best practice here (and standard in broadcast) is to have the AMM sit post fader in the signal chain. Instead A&H have opted to have the AMM be pre-fader but the key for it is post fader, they call this âfader followâ. That works great except for the fact the case where you want to PFL a channel to listen to EQ and compression, but you must also listen to the AMM gain reduction.
I hope that explanation makes sense, Iâm very tired after some very long gig days with lots of travel.
@Kiethjah Yes, my bad, I misspoke in calling it an issue or a bug, and I completely understand that those sort of changes require significantly more work and resources than a maintenance release allows. Hopefully A&H see fit to look into this and make some changes as it really is the only thing holding this console back from being a serious competitor against the Yamaha QL in broadcast world⌠Which is amazing considering the massive price difference between the two consoles.
@KeithJ_A&H - let me whole heartedly agree with what @Carl_N says about the superb features and value of the SQ, and please forgive me as I donât understand the complexities of programming the firmware for a console like this ( or indeed any digital console ), but it may be a âquick fixâ to allow an option for the meter and PFL point to be moved to between the delay and AMM blocks, and / or just pre the delay block, this would give you level and PFL at a much better point for use of the AMM.
Thanks.
CarlâŚ
ok I think I get your point, default PFL point could be post delayâŚ
but the gain stage of the AMM is pre delay
you can set your PFL point to post EQ, so itâs before the AMM
I was doing it exactly like this, to have PFL and a working AMM
@SteffenR, Yep, that was one of the workaround solutions I came up with, the downside though is that PFL is then pre-compressor, not a deal breaker but still frustrating as compression is of course very important for talking heads broadcast content.
Another workaround that I came up with, and the one I currently use, is to have the AMM page open on my laptop and individually take mics out of the AMM to PFL them. This gets tricky though when you have lots of mics and have moved faders around on the surface so they are no longer in the same order as on the AMM page.
