I am on my 2nd SQ board. 1st one had a pad pixel and only had it for a couple days. Received the new one today, updated the firmware, plugged in the USB-B cable from my iMac. I am using the USB out, which is set to the In1/2. The previous board fired audio out of iTunes after I set the SQ out for audio out. Doing the exact same thing and nothing playing through this board. I did hard reset the board.
check if usb source on your Sq is on “USB-b”.
Since 1.5 the selection between USB-b and sq-drive mode has been moved from I/O page to setup (page where you can also choose between 96 or 48 KHz).
This was the problem. I guess I did change it on the other board and forgot. Thanks!
Happy to hear I could help ?
