SQ5 - Dummy Mode through App?
we soon will have a wonderful SQ5 installation in outh theatre. Perfect for all larger events with a trained engineer.
But… during weekdays we sometime have seminars and business meeting with no engineer present. Imagine the Yoga Seminar with the 75 old teacher who want to play some background music… Then, only two wirless microphones and the sound from the beamer (resp. through HDMI from the notebook) is more than sufficient. So, I’m looking for a solution how to ideally:
x lock the SQ5 in some cabinet
x give the presenter an Ipad with an App
x App only shows: volume for Mic 1, volume for Mic 2, volume for HDMI, volume for 3,5 jack (from mobile phone e.g.)
x there is no possibility to change anything else
Do you have any idea or suggestion who to solve this? I’am afraid opening the SQ5 to this audience would cause a mess - once the wrong button is pressed, an enineer has to come to fix it again.
Thank you for any good idea.
Check out “Guided Access” which is a feature of the iPad. I’ve used it with Qu in the past, and see no reason it wouldn’t work just as well for SQ.
With this you will be able to force iPad to use only the SQ app, and lock the touch screen area that you don’t want touched. So you’ll probably end up with just a rectangle active containing 4 faders, though you could allow the mutes too in a second rectangle.
I’d probably set iPad to show only 8 channels, with blanks in between the ones used, and use long fader view.
Hi Mark,
hmm, this is a pretty unorthodox solution but sounds interesting.
Here’s a completely different idea.
How about having a small sub mix system on the stage, compact analog mixer
with as few knobs as possible, wireless mic, audio for video input and a
bluetooth receiver.
Have that sub mix system summed into the main system at the system processor DSP (if there is one) or hitting an input on the main mixer.
The QU series Q control APP would be perfect for what you want to do, but the SQ does not
have that option.
The forum just kicked me out. I wanted to say “thank you” in addtion.
As I don’t have an ipad currently - are the blanked out parts invisible or just intouchable?
Well but that would mean than in a concert situation that I cannot address the two mics and the beamer separatley as they only come as a ready mix into the SQ5?
Those inputs could be split between the two mixers.
I’ve doen this at a couple installs for the very same reason that you asked.
I set up a small on stage sub mix system and by recalling one of two presets in the
system DSP they can select between the main FOH mixer or for day to day the small
stage sub mix system.
Blank parts are “untouchable” - you can still see them.
From your picture, I’d slide the centre bar up, as info on preamp & delay is not required by these users
I’m going to keep that in mind, was not aware of that.
