Would you mind telling us what version of MacOS you are using? I was able to update the firmware before but now in Monterey I can’t read the SQ formatted thumb drive.
It must be the older version of the macOS that is giving you the success. I’m 12.6.3 and can’t read any thumb drive formatted by a SQ sound board. Borrowed a Windows laptop last night and it promptly read the thumb drive. I wonder if this means there is no support for the newer macOS and the SQ boards.
Confirming previous posts regarding MacOS Sonoma. I had the same problem with SQ-5 firmware update using Sonoma MacBook Pro, after four years without firmware update difficulty. Downloaded the upgrade package to my usual SanDisc thumb drive on an older Mac with earlier OS, upgrade successful. Allen-Heath does have a warning regarding Sonoma compatibility on the download website page.
I downloaded the firmware update on macOS Catalina unzipped with Terminal copied to a flash drive (formatted on the SQ) and the update was recognized and successfully applied. I tried the same procedure on the lates macOS (14.x.x) and it did not work. This would appear to be an issue with how macOS is unzipping the file. I would be surprised if it were a copying issue, but could be? I guess.
I too Had the same issue with my SQ6. I tried multiple drives, did everything at least 3 times on each drive. Found a drive thats USB2 and bam. worked immediately. I love AH and SQ but this usb drive is my biggest gripe. if we HAVE to format then at least it should work for any usb drive. Unfortunately its a problem and not just an oddity.
Same issue for me: SQ won’t recognize firmware “BIN” file, and I don’t have a computer with older OS to move the files over from. Can Allen Heath provide a downloader application so we can successfully get our firmware files to work?
In short, the recent macOS does not truncate and number filenames in a standard way, but it’s possible to rename the file manually before copying to the drive.
