I am trying to use the same LR FX and also sending it to a mix. It should be dirt simple, but I must be missing something.
Sample: I have 3 VOX channels with reverb on the main mix. I would like to send the same effects using the same FX engine and have it also go to one or more of the monitor mixes.
Thanks for helping, I am fairly new on a digital board.
The FX returns are what you’re after here
They work in much the same way as the input channels, so you can assign them to any mix and then individually adjust their send levels to the each mix too.
