SQ5 - Midi: Levels Value
Hello,
im very happy that the SQ now have a Midi Control.
I have now the problem that i not know how the Value Coarse and Value Fine of the Levels is composing.
Have anyone found the logic behind? Or what is the formula to convert the db in vc/vf and converse.
The Example Level Values on the SQ-MIDI-Protocol-Issue1 does not help me.
I don’t use any midi programs. It will be a self-programed program.
best regards
xDGeForcexD
Hi @xdgeforcexd,
Great that you’re making use of the new SQ MIDI control!
Unfortunately, due to offsets and scaling it’s not a simple conversion (hence giving examples from -inf to +10dB in the protocol doc).
You could obviously take a look at the MIDI output to find values, but if you contact us using support.allen-heath.com and let us know exactly what you are trying to achieve here, we should be able to help you out.
Cheers,
