SQ5 No login screen when powering up
Hello,
Problem is when starting up no login window is displayed ..it acts as though I’m already logged in. also Main scene is loaded but appears as “no scene” under current. I have to go to scenes and load the main scene to have it updated to current.
I updated from 1.6.1 to 1.6.3 but problem persists …I reset console and reloaded show …twice ..no difference …
I know this is not normal behaviour as the login is supposed to ask me if I want to load saved show then populates main scene under currant scene after login.
any suggestions?,
Probably needs to be serviced.
Once you have started, try loging out, does the login screen then appear?
Have you setup a user with a password and a default screen for that user?
If not, and this is trying to drag information from my brain from many years ago, the default behaviour is to startup from where you finished at. There is no ‘user’ to login as, no password set, and no default scene specified.
If you create some users, and don’t specify passwords, when you login as one of these ‘no password’ users, the default is to log back in as this user on a start. You have to logout and then log back in as a different user.
Warning, create a ‘super user’ first! Make sure that works, and then add a password to the default user supplied by A&H.
Dave
hey thanks…turns out, that’s it…it had been so long since I set it up that iI forgot that step.
Thank you
Glad that sorted you out (and my brain could still remember that!).
Dave
