My sq5 is not booting.
When I switch on, the ambient led light comes on.
The green led of mic/channel 5,6,7 and 8 light up sequentially and this continues forever.
Please help
Please help
Hi @Ahmed
This suggests the firmware is not loading and may have been corrupted somehow.
The unit has gone into a mode where itâs checking the SQ-Drive port for firmware to reinstall.
Please try downloading a fresh copy of the latest firmware for your SQ-5 (https://www.allen-heath.com/sq-series/sq-5/#software) then format a USB drive to FAT32 (as you will not be able to format in the console) before placing the unzipped firmware file in the root of the drive, safely eject and then connect it to your SQ.
If youâre still having trouble, please contact us using support.allen-heath.com
Keith
Hi there,
We have had an SQ5 for less than a month now and have the same issueâŚweâve done the firmware update a few times and it still doesnât switch on.
Please help
Sorry to hear this.
You can contact us directly for help using support.allen-heath.com, or, especially being that the unit is brand new, contact your local dealer or distributor to have it looked at, sorted and back to you ASAP.
The full list of our distribution partners can be found here - https://www.allen-heath.com/where-to-buy/
Hi
I too have this problem> I have downloaded the new firmware but as the SQ5 wont get past 4 of the channel sen lights flashing it doesnt seem to be able to download the firmware. I also tried a hard reset and that didnât;t work either. Got to say this is disappointing, only 2 months old and used 3 times. I was due to use it at 2 festivals this weekend but will have to stick with my GLD.
Mick
Hi @Radar,
Iâm sorry to hear that you are experiencing the same behaviour on your unit.
As my colleague Keith has explained, this behaviour is suggesting that the Firmware in the unit is corrupted and the console has entered a state of âTrying to find the Firmwareâ, unfortunately this may require a Hardware procedure.
As advised by Keith, please reach out to our Support team through the following channel: Support@allen-heath.com or directly to your nearest A&H distributor: https://www.allen-heath.com/where-to-buy/
Thank you,
Rafael
Hi guys,
I have a 5 Month old SQ5 with the latest 1.5.9 Firmware running.
It was always running properly without any freezes or other issues.
Today I was listening to a Multitrack via Headphones and suddenly there was a loud an constant squeaking noise on the headphones and then the SQ was frozen.
The first Reboot ended with a strange Display. Now it doesnt boot anymore.
Only a few lights are blinking.
Pushing the two buttons to force a Hardreset do not work.
I can confirm this fixed my issue. channel 1 showed firmware but nothing was happening so I hit the PAFL button and that seems to start the process. I received a brand new mixer from sweetwater and the screen was blank, doing the firmware piece fixed my issue.
This was the missing piece of information from the above.
My unit had âF/Wareâ illuminated in channel one, but nothing happening.
Hitting the PAFL button to load the Firmware was apparently the missing piece of information.
Thanks so much to all on this thread.
(phew)
