please give us a feedback to the assignable encoders by how many dB we have changed the value.
without info these encoders are not very usable
+1
and routing option for PAFL to physical output!!!
Also a +1 from my side.
See two possibilities both should work during changing the value:
- Display of the numeric value
- Display of a progress bar.
Best would be both with the option to choose
It is possible to assign processing parameters of the current selected channel for the encoders.
I would like to see the parameter name instead of the channel name in the display of the encoder. Example: I use two encoders for the gate depth and compressor gain. Now I see the name of the selected channel two times for that two encoders. Better would be ‘range’ and ‘gain’ or similar
Yes, I have put my EFX on the “Soft Rotaries” and so I see the name of the EFX but turning the knob I have no idea how much I have changed the db of that effect. So please have it display the db when turning the knob.
yessss! please!!!
Let me suggest that this be treated as the more general
“Jump the Big Screen to the appropriate page when the user turns an assignable encoder”, as has been suggested elsewhere; it’s slightly more general.
And “Make PAFL a selectable source on Matrix Outputs/in Routing” is probably the definition of the other item.
