Is anyone using a Mac with Ventura as the OS with an SQ6?
FYI, Monterey works perfectly fine. But need to update OS. Thanks
Are you trying to use it directly via USB or through the MixPad apps? I’ve been able to use Ventura on a Mac using the MixPad app, but I have a separate computer running Monterey that is directly wired via USB to the mixer and have not tried it.
I would guess that USB-C to USB-B could be tripping it up, if your mac is new enough and only offers USB-C outputs.
Thanks for the fast reply. I would use it for the MixPad. Sounds like that will work. We use cell phones for the monitor mix adjustments. I have not connected my macbook pro to the SQ6.
What are you using the your computer with Monterrey to do in the SQ6? Thanks again!
