No output from local send outs .the desk is patched correctly on the i/o page works with GXstage box but not on any locals ,the output meters register and pafl but no audio at sockets on rear of desk. Baffled ……….
@Ctp
The quickest test to rule out any software or setup issue would be to back up your show to USB then carry out a hard reset, connect up to output socket 11 or 12 and use the SigGen to send signal to the main LR.
If you’re not getting any signal, this could point towards a hardware issue, in which case please contact your local distributor to get your SQ fully checked over and carry out any servicing if required.
Keith
Taken it in ,the dac is overheating and shutting off all the locals.
Thank you.
