SQ6 Won't Control DT168 Inputs
I plugged my DT168 in my SQ6. That inputs with active P48 showed up on the DT168 from the last job. Everything is correctly routed both on the SQ6 I/O patch and in Dante Controller. I have plugged a P48 mic into an input on the DT168 and it shows up as working correctly on the SQ6.
However, the input controls on the SQ6 are greyed-out and I can not turn the P48 off on any of the DT168 inputs.
Both units have the latest firmware.
What am I missing here?
Doug
So, false alarm. I had tried this early on but a second time unplugging and plugging the Cat cable into the DT168 brought the preamp controls back to life.
Whew!
D.
