SQ7 preamp gain is changing the PEQ screen
When working on the PEQ screen for a channel, if I alter the preamp gain using the rotary knob, it takes me away from the PEQ screen, back to the expanded channel view.
Is there a way to stop it changing screen? It doesn’t happen on my SQ5, I can continue to look at the PEQ screen while altering the preamp gain on it.
Firmware update to the most recent version hasn’t changed the behaviour.
Can you look at the Setup > Surface tab and see if the “Processing Screens Follow Surface” button is ON or OFF.
Compare your two mixers…
Some people ‘play’ with some of these settings and (once changed) are there for good unless they are changed back again…
Dave
That’s fixed it Dave, thanks for the help.
Excellent news. I thought it would…
Dave
