Odd…I recorded a song at our rehearsal tonight, with my digital guitar rig plugged into ST3, and all sources set to local.
On playback, the mics are there as expected, but ST3 is silent. And ST1 is playing back the full mix.
Do you have to do something special to set it up to record ST3 to the QuDrive?
have you read the manual? i think it’s on page 35 → Qu-Drive!
It’s page 42 of the latest version!
All 18 recording channels can now be selected to be whatever you want on the QuDrive now, but the default setting is that 17 & 18 record L+R (which then plays back through ST1).
You need to go to “Setup” > “Output Patch” . “USB Audio” and change it there to what you need.
Dang. Okay, I had missed that. Thanks!
Does the output patching for the Qu Drive get saved with the scene, or is this going to be another one of those things I have to double check every time?
Relax!
It seems to save with a scene & is remembered when powered down.
I can confirm that it is part of the routing data within a scene, and is blocked when the “Output Patch” scene filter is set.
DC
