Stereo assign, different gain level L/R
Is it possible to assign two faders to stereo, but using different gain settings for L and R? We use two microfoons in a piano, and set to L/R (assing stereo and use 1 fader). But we have different gain settings per microfoon. Is it also possible to manual pan the L and R different from each other?
I think yes, you can put the two mic on 4 input channels (one mic on 2 inputs) with the patch and than, have two differents stéréo from the same pair of mics.
Thanks for the answer,
An other possibility is to set to mono assign (2 channels) and use 1 DCA group. Then we can use one fader to control the piano with complete different gain/EQ. On the fader layer we assing for the piano the DCA channel.
Peter
Hi Peter,
there are only workarounds available like posted above because SQ doesn’t provide a linking/ganging function at the moment like QU, GLD, iLive, dLive does.
I mentioned this lack of function several times in the suggestion area of this forum and hope that A&H will consider this feature in one of the next firmwares.
At the end…switch two mono channels to one stereo channel is not the same than to “link” two mono channels where you can choose the parameters that needs to be linked and which not.
Have a look into the QU User Guide (Linking channels)…that’s exactly what “we” need :slight_smile:
Best regards,
Sascha
Sascha,
Tanks for the answer. I agree with you. I hope that this will implemented in the future.
Peter
