Stereo Link outputs 1-4
Is ist possible to link outputs 1-2 and 3-4 for stereo in ear Monitoring?
Or do the additional outs of a AB168 offer this behaviour?
Would be great to have stereo Monitoring for more than 3 musicians
If all mixes should be the same, why not using an analogue split cable?
The stageboxes allow free assignment of their sockets to many sound sources, you’re free to map all physical sockets to the same source or a stereo pair…
No i need 5 individual stereo monitor mixes and was hoping to be able to configure all outs as pairs. But they seem to ne locked in mono (1-4) and Stereo (5-10) modes :frowning:
There is no way to get any more than 3 stereo mixes from that board. I find some musicians insist on stereo and some do not mind as much. Be choosy and give the 3 to those who simply cannot go without stereo and the 2 mono mixes to those who are not so fussy….
If you’re doing this for just one band and the mixes will stay the same over time, you could work Mixes 1/2 and 3/4 as stereo mixes and control them with DCA for a faux linkage.
It’ll take a bit longer to set up but should suffice.
Please explain this. :slight_smile:
You have purely independent mixes for left and right ears. Not nearly as easy, but it can be done…
A DCA on the master levels allows for overall volume control to be controlled.
But how can i then adjust the pan of a mono signal in the mix since there is no pan-control in the Mix 1-4 sends. The only was seems to toggle between MIX1 and MIX2 and make sepeate mixes for Left and Right ear, which is rather inconvenient (maybe impossible via the quYou app)
You have to adjust the levels of send to the left and right independently. This is, as you say, almost impossible via QU You - although they could use two iDevices, one for each ear…
This is, as you say, almost impossible via QU You – although they could use two iDevices, one for each ear…
Funny idea though :)
I think i’ll place this as a feature request then.
But back to the AB168. Do the 8 Outputs act as adittional Mix-outs (11-19) when connected? And are thes strictly mono as well? Or could i just patch the local Mix-outs 1-10 to the stagebox?
Any mix output can be sent to any of the outputs on a dsnake, they aren’t additional.
Ok thanks a lot for your help, guys!
This includes L&R as well as any groups and matrix outputs on the larger desks I think
