Stereo sound in headphones and aux5
Hi there
I use my sq5 as a daw controller and audio card, in my studio.
Today I set up aux5 to send a balances stereo signal to my headphone preamp in the other room, for a singer.
I don’t get a stereo feed I think. Sounds very mono.
I then took my DT-770 pro headphones and plugged into the sq5.
I don’t get a stereo signal there either.
Have tried all the options in the PAFL option on the sq5, listening on the headphones.
To keep it simple I play a stereo track from Spotify into my stereo USB input, on the sq5.
If I listen on my speakers, I can pan left and right, and hear a stereo signal, no problem.
If I listen on my headphones plugged into the sq5, PAFL enabled on the master fader strip, I get mono.
Please tell me what I do wrong?
According to the manual LR to PAFL, should send LR to my headphones.
Same problem with the Aux5 stereo send to the other room.
Kind regards Kennert
can you send your showfile?
as a ZIP
I World like if someone has an answer to my q’s ?
showfile?
@Wayonken
Did you setup the aux to stereo?
Do you adjust the stereo panning for the aux mix? It is independent from the main mix panning.
Did you adjust the width of stereo channels correct?
Btw. The crystal ball is currently out for maintenance, so you have to give us more detailed input (e.g. the zipped showfile) to allow us to help you.
Kind regards
