StereoMix Invert function
Hi!
Does anybody use StereoMix Invert function? It looks like it doesn’t work…
Using AFL control on stereomix, try to switch this function on/off and play with pan,
but nothing is changed. It seems to work with Follow Main Pan only.
Andrey
it makes no sense without “Follow Main Pan”
then the Pan in the sends is independent from the main pan and can freely adjusted
“it doesn’t make sense without “Follow Main Pan”.” → I see that as well.
i don’t use this function yet, because i want the inear mixes to be completely independent from the frontmix. i adjust the FOH-pans almost every time i mix a concert, because the situations are always a bit different. the inear mixes, on the other hand, usually stay the way you set them.
