Hello all! I’ve been using my Surface Pro 4 to record from a Qu-32. Unfortunately, occasionally I’ll get this nasty audio interface. I’ve had this happen in both Cubase and Reaper. The waveforms look just fine, however, when playing the audio back either through the mixer or a pair of headphones - I get this awful sound. I’ve tried making sure I’ve had the surface connected to a power outlet during recording as well as using a good quality USB cable.
Try to record directly to a USB stick in the Qu drive. If it’s clean, then the problem is in your Surface and you’ll have to find out what’s happening there.
I doubt it has anything whatsoever to do with using the Qu-32 for your input.
Never forget that with a Qu32 you always have 64 audio channels streaming, even when recording only stereo. This requires a well performing system etc. Did you check if power management is disabled while running Qu streaming? And, of course, ensure recording samplingrate is 48kHz not 44.1. Disabling oboard sound while using Qu may help as well.
