23… I was expecting 32…
yes, 23 is irritating me also. But you can easily count dots (=samples) from left selection up to the cursor, its 23.
I want to be as accurate as possible. Is that a bad thing?
The way I look at it there is always going to be certain margin of error. If I do everything I can to be as accurate as possible, the smaller the deviation when everything gets added together.
I understand small discrepancies don’t cause concern in you fellas. And that’s great. But I want to be able to get as close to perfection as possible without having to nudge and move around once everything is set.
Nothing against perfectionism, I’m in that club as well. But discussing about a msec more or less isn’t really worth it. There are much more critical topics to check when it comes to live sound (we’re still talking about monitoring, right?).
To be frank, I’m also thinking about mixing. For live such small numbers are perfectly fine, but when it comes to recordings and using this board for creative mixes even small amounts start to make me weary.
The 16 was marketed not only for live use, but for installation & studio as well. I am trying to determine if despite of what A&H claims this board can be useful in a small studio.
So far I’m starting to think that for a “full featured” board one has to step up to the Qu24 or 32. No, I’m not saying that the Qu 16 is a child’s toy. It’s a great ‘little’ board, but there are limitations that bum me out. I feel I should have stepped up and gotten something less… lmitating. Turns out I use subgroups more than I thought.
My only hope is A&H decides to provide is with a patch that would allow for stereo mixes to be internally route-able to the LR.
Thanks for reading my rant. I’m sorry if I sound too needy.
But for recording this latency is absolutely irrelevant and normal for any type of digital recording, sorry. Even with the lowest possible ASIO buffer sizes you’ll add much more latency to the overall system. But this may completely eliminated from latency compensation. Either this is done automatically, depending on your host system and DAW or should be able to be adjusted manually.
Of course you need to verify and optionally adjust your system once to obtain zero latency (playback signal through monitors, record that with a microphone and a second track and peaks should match). But this all makes sense only, if your musicians are “synchronized” to headphones, otherwise each foot (30cm) distance to your monitors will add another mSec delay. Much more that we have from the Qu (or any other digital system).
Okay.
