Sudden volume increase, all faders, when crossing -10 dB
I am getting a sudden significant jump in signal when faders are moved above ~ -10 dB.
This is true when changing aux, main and individual channel faders.
Signal output is very low below -10, then immediately upon crossing -10, the volume level (headphones using I/O from a new DX168 but it also happens when using local inputs and outputs) jumps considerably.
For the monitor feeds, this jump is accompanied by a noticeable increase in hiss, I guess from the additional processing that the Aux have. This effect is less when using local I/O and less still via the DX168, due to better preamps maybe.
Additionally, when I have for example Aux1 selected so that changing the Aux1 fader also changes the Master fader (now the same role as as the Aux fader) and I increase the volume of either the Aux or Master faders slowly past -10, the faders kick back at me and take a little shove to get past -10 and into the “loud” zone.
I have removed every speck of effect, eq, etc and no change. It’s almost like the whole board is being gated at -10.
I just tried feeding pink noise from the signal generator into the L/R mains, and the PAFL level goes from ~-40 to -6 the instant the main fader is brought above -10.
Also, I had a fader go bad last week, it only jumps between 0 and 100. Possibly related to this other weirdness…I have a new fader but haven’t put it in yet - what’s the point now?
I have done fader calibration, firmware re-update and a hard factory reset.
It’s possible that this issue has existed for a while - I never have the main fader below -10, and recall instances where damn, the monitors are not as loud as they should be yet I’m sure I should be giving the artist plenty, and I do often run aux near -10. Hmmm
Any ideas? I think I need to rent a board ASAP, 2 crucial gigs Fri and Sat.
Thanks for any input!!
So, this affects all physical outputs, as well also the internal listen (AFL) via headphones!?
And did you check the strange behavior of the faders immediately after the factory reset - without loading a show?
If so, in my opinion, it could really only be a hardware issue.
I assume you have already reported this to A&H; I, too, am curious to see what the outcome will be.
I had this happen on my Avantis after a fader calibration routine. The only way I was able to get the gain law back to normal was to back-rev the firmware to an easier version and then go forward again to the latest. I reported the issue to support. They weren’t aware of this being an issue.
It reads as though these are different issues.
If I understand correctly, your problem arose as a result of a fader calibration, whereas the OP was attempting to resolve his issue by performing a fader calibration.
Since the behavior is the same regardless of how the OP’s desk got there, I suspect my fix may apply there as well. I tried multiple fader calibrations and factory resets to fix the issue to no avail. The firmware dance is what brought it back. It certainly couldn’t hurt to try if the OP has had no luck thus far.
Never had a problem at all staying at firmware 1.5.x. Glad i never updated, sounds like 1.6.x is problematic, and A&H seems to have totally bailed on this board.
Short story: Everything works now, without a trip to a service center.
Long Story: Based on suggestions here (thank you) I rolled back the firmware to 1.5x - Didn’t fix the problem where levels jump when any fader moves past -10.
I hadn’t yet tried to use a tablet to see how the tablet volume control tracks vs. the physical fader. It was very strange - when I would move the tablet fader from 0 to 100%, the corresponding physical fader would go from 0 to 100% over the first ~50% of the tablet level, then go back down to 0 as I increse the tablet fader, and then the physical fader would go from 0 to 100 over the final ~30% of the tablet fader level. So, a steady increase in the tablet fader would make the physical fader go up, then down to 0, then back up again. When I move any physical fader on the board past -10, the level on the tablet jumps maybe 30-40 dB.
So, same “broken” behavior as before, when using the tablet (with either Mixing Station or the dedicated SQ app). So, at this point I am still convinved that I need a trip the a service center. The board just simply does not work, even after a firmware cycle and a hard reset.
So I try another hard reset and do not load any scenes . No change. I try another hard reset (the third overall, I think). Everything now seems to work (except for bad fader #14 which I swap out below). Digitally displayed volumes now track perfectly with the physical faders and the faders on the tablet. Faders do not physically kick back at you when crossing -10. When I send pink noise to LR and increase the fader, the displayed PAFL volume level increases corresondingly - no jumps. I am happy.
While I would not believe it if someone told me, it appers that it took multiple hard resets to actually reset the board - one reset was not enough to clear out whatever was going on deep down inside.
Pure speculation - I had been possibly using the board in a less than ideal way, in which each band, each venue, each gig, essentially, got a new SCENE (not SHOW). So I had maybe 50 unrelated scenes, some of which I would overwrite if I knew I wasn’t going to see that band again. This practice happened over ~ 3 years. Is it possible that some scene(s) became corrupted and left a trail of dog doo in the soft/firmware, and that it took a few hard resets to clear out the junk? Hard to believe it but I saw it happen. Unfortunately, this happened after the weekend’s jobs for which it cost > $400 to rent an SQ6. What is the best practice? Does each gig get its own SHOW?
I then opened her up and swapped out my bad fader 14. It calibrated perfectly out of the box, no fine tuning necessary. Reminder - except for fader 14 pre-repair, all faders calibrated perfectly every time I tried throughout this whole process.
Moral of the story - you may think that your board is totally whacked and unuseable because the faders do not work properly, but through a series of hard resets I was able to restore normal function.
Thanks to everyone who made suggestions - they really encouraged me to did a little deeper instead of running to a service center (who, in hindsight, might not have been able to fix it anyway, given what I did)
