If you have several shows and you open one in the editor, then there is no way to see witch one you have opened. So you could easely save over an existing show. Is there a possibility to see the name of the show you 'r working on in the editor?
Same for the surface patch in the editor 1.43 .You can not tell from within the editor witch input/output is which on the surface. It is verry confusing and was beter in version 1.42.
I understand that it was changed to be compatible with the big ilive.
Lieven
