Suggestions for the next firmware update
I would like to see a preview from the PEQ library before I apply it!
GLD-80, AR2412, Peavey Versarray 112s 218 & CS Amps eh
Pull up the EQ preset without the “IN” button engaged
Vice President of Sales
Allen & Heath USA
being able to run a compressor in one of the fx busses so you can run parallel would be awesome.
and the multiband compressor from ilive
  • 1 for the multiband compressor!
Also i BEG A&H to do something about the delaytimes in the FX engines. 1.36 seconds is just not long enough!
And what about beeing able to setup the musicians iPads to adjust their respective monitor-mixes? I had that on my Presonus, and it’s a FOH-tech’s dream!
Willy
FOH-tech.
GLD-80
AR2412
AR84
You can return an FX unit to a channel(s) which gives you the same processing you have on any other input (gate, comp etc…).
What would be good if the hardware allows it would be an option to “decativate” un-needed processing channels as part of the config setup (probably in blocks of :eyes: to allow that processing power to be traded for more mix outs, multiband compressors etc.
Would a longer max delay FX time be do-able? It would be a nice option even if it meant using up two Rack FX slots.
Chris
My wishes for the new update:
+1 for the multiband comp.
more delay time tap delay
sidechaining the compressor - select an aux bus to feed the compressors ‘source’.
Allen & Heath USA
I tried this - deselect IN, pick EQ preset in library, recall. It loads the preset and selects IN all at once - no preview.
Is the “IN” status saved as part of the library file?
What happens if you deselect “IN” and overwrite it, then recall it again?
Chris
