I would like to run SRP with my SQ5. I will only need it to run 2 reverbs and a delay. So latency won’t be a big problem.
Can I just hook the SQ5 up to my MacBook Pro via USB?
If I would like to feed Audis from my SQ5 via an AUX send in the console, is that possible?
I run a compressor chain and other processors from SRP to the insert on an aux for our live stream. The insert is the first processing the signal gets after the input. Routed from USB channel from my MacBook.
