surface frezze
Hi all, two weeks ago i was working with my T-112, IDR48 firmware 1.82, all works fine but the surface just frezze, all keep working in the IDR, nothing responds on the surface, I try to go to the editor software on my laptop (wifi connection), surprise, IDR was not there, I try then to go on my Ipad and the same result, IDR was not there, try then to connect my laptop by cable directly to IDR and the same result, IDR does not appears, It was 1 hour before show ends, so in all these time i losse the control over the mix even the IDR keeps working, I can´t turn off the IDR in a middle of the show, but I did when show ends, previously I test my network cables (CAT6) and both works fine, so after I restart the idr and the surface as always all works again fine, the surface, editor (wifi) and the Ipad all at the same time, the messages on the even logs was the follows:
Touch screen: ACE Port A QOS Warning
Surface: accept returned -1, errno is 24 (httpservthrd.cpp:170)
IDR: accept failed, Error = Too many open files in system (servthrd.cpp:153)
Ok, next week, all works fine, but the red croos on the firmware appears, the event logs was the follows:
IDR: accept returned -1, errno is 24 (httpservthrd.cpp:170)
any idea???
Comfortably numb
Hi again, the firts router I used was the airlink AR335W, “g” mode, I´, used just with the editor on my laptop wifi and works pretty for me, a little slowly but functional, and never have a problem like this one or other type, when I star to use the Ipad I chenged the router and is the one im using today, cisco WRT120n, curiously, the ipad and the editor works better in the airlink router than the cisco router.
I will send the event logs directly to A&H support.
Thanks again
Comfortably numb
Address conflict?
Tim Tyler
Detonator Sound
Richmond, Va USA
T112/48 R72/32 laptop iPad Dir-815
Mmm, dont think so, mi Idr, surface and touchscreen was in the default addres, the router was 192.168.1.254, the range of addres is from 100 @ 200, so the laptop was on 192.168.1.106 and the ipad on 192.168.1.103
Comfortably numb
How long did you let the surface boot?
Just asking, cause as that was happening to me - the surface showed “connecting” about 5 Minutes till it was connecting right.
Albin
the firts time I reboot the surface was along 3 or 4 minutes, then i changed the network (thinking the cable was the problem) and reboot again more than 10 minutes, because in that time im was trying to conect the laptop and editor and the ipad
Comfortably numb
bad news, it do it again, this weekend I have 2 shows, I changed my network cable and replace it with a new one, no red croos on the main firmware, but surprise, when I tryed to open the system with my ipad, surface frezzes again, then the same history, so in a middle of the show I have to turn off the IDR and turn on again, all works again but I dont use the ipad or editor, any idea??
maybe router problem??
Comfortably numb
Comfortably numb
I have seen this typically in either network ip conflict or various other network problems…I am suspicious as to how you are attempting to use this since you are trying to connect during the show!! should you not be all set and ready to rock by show start ?
Can you elaborate a little bit more as to how you are doing this and in what order…seems odd that this would work for the rehearsals but not during show time…also does this freeze ever happen without a wireless network ??
RayS
R-72/iDR32/iPS10
any idea???
Comfortably numb
Red X errors in iLive manual https://www.allen-heath.com/UK/CategoryDocuments/iLive%20Reference%20Part%202%20Firmware%20AP6526-2_5.pdf page 97
I would connect laptop editor to iDR hardwire, if things were to go down elsewhere in the chain you’d still have control.
Hopefully someone from A&H would respond on the possible cause of the freeze
hope that helps
RayS
R-72/iDR32/iPS10
i´ll send the event logs to A&H tech support, the entire archive, and, this saturday I will to update to 1.83 firmware, hope all works fine, thanks RayS
Comfortably numb
Did you reboot the surface?
Had this once - but without the red cross.
The surface lost all of its LCD Colors and stops responding.
Rebooting the surface brought it back up.
But since you couldnt even connect to the MixRack it seems that the Network Board went down.
For shure A&H Tech support could help you - please keep us informed as well.
Albin
Hi Noeme
As albin has suggested did you try and reboot the surface on its own not the mixrack? This could of got you out of trouble as long as you were not using any I/O out of the surface at that point of the gig?
There are a few possible reasons why this could happen:
the ACE QOS would suggest a possible problem with cabling between surface and mixrack. This could then effect connection to the surface and then editor and mixpad depending on how you were connected editor (‘surface & mixrack’ or ‘Mixrack only’ connection), and where the router was physically connected to the system mixrack or surface would also have made a difference?
The actual reason for the freeze of the surface could of potentially been caused by a connection failure between editor and the surface.
changing to multicast connection may have helped the freeze problem if editor/mixpad lost connection to the surface, or connecting editor via ‘mixrack only’ may have helped, though this is not recommended in all applications due to the complexities of running a virtual surface next to your real surface.
The point you made about connecting the laptop to the mixrack via cable after and you could still not see the idr is interesting.
Best for Tech support to help you resolve this one.
Goodluck
Regards
Sam A&H
Thanks for your helping, the time the surface goes frezze the LCD colors still on and contain the entire information as well, the meters on, the touchscreen on, but the problem was the frezzen, and then nothing responds, I try to change de faders bank, press SEL button on various channels and nothing responds, I try to reboot the surface maybe 3 o 4 times and the surface just try to conect to IDR but nothing, even no message of any error, lost connection, nothing, just the blank screen before conection, I changed the network cable but the result was the same, then, I tryed to conect my laptop editor but the IDR was missing, I tryed to do the same with my Ipad but the same result, IDR missing, other test was I leave the IDR alone without any cable, the ACE cable and the router, then I conect my laptop directly to the IDR with a cable and nothing, conect my router (cisco wrt120n) and the flasing ligth on the router tells me tha the IDR was there but my laptop cant see the IDR, when the show ends, reboot the IDR and the surface and al works fine again, the surface, the router, the editor and the ipad, even at same time.
maybe you can have a better idea if I post the archives of the event logs, but how can I post the archives of the event logs so you can see the entire log?
again, thanks for your help
Comfortably numb
Hi Noeme
I am afraid I cannot directly support you here. This is best dealt with by technical support.
Regards
Sam A&H
When I first got my T112/idr48 last year, I had a problem with my surface “turning off” when using editor wirelessly. I was using a “G” router, and changed to an “N” router - and the problem stopped. I tested the system as many ways as I could think of with the “G” router and had the problem until I upgraded the router. I was in contact with Allen & Heath about this problem, perhaps they still have my correspondences about this. I have had no problems since.
Just a thought…
Tim Tyler
Detonator Sound
Richmond, Va USA
