When playing back multi track it would be nice to have a option on the Qu-Drive screen to switch inputs to Qu-Drive as a enable/disable toggle. Or have an option to auto switch on playback.
Before firmware update this was done in the USB Audio page but that page has been moved/removed with the 1.1 update. Now you have to select a channel, select processing, select preamp, press the Fn button for source select. Now you get the Source Select page.
There must be a better way to easily select Qu-Drive USB from the Qu-Drive pages.
yes, please. It’s too inconvenient to have to switch all channels by hand to hear the record, then switch all them back to record again…
yes please
Yes please if the source select page that was taken off the Qu Drive menu options in update 1.1 could be reintroduced it would save having to go through each channel 1 at a time to set input source
