System Compatibility
Hi! My company is about to pull the trigger on an avantis solo, we are looking to daisychain an AR2412 and a AB168 to the Avantis, could someone please confirm if this setup it’s compatible? I’ve found that it works properly with the SQ but I need to confirm before making any purchases.
I believe you won’t have any issues, as long as you don’t try and add a gx or dx series stagebox to your system. The Avantis will see that your stage boxes are running at 48k rather than 96k and therefore use the proper protocol, but you can’t use both at the same time.
