sztereo mix follow master L-R pan
Can a stereo mix (Aux or Grp) be made to follow the Master Pan ? more precisely, an input’s pan is the same in both the zMaster mix and the selected Aux mix.
Ray
if you send the channel to a stereo-group, the pan is also taken over.
if you send the channel into an stereo-aux, it’s not.
that’s the same with other consoles.
k thx
Ray
@ Wolfgang - not necessarily true. Venue has the ability to globally link main pain per buss. IE, in addition to the group function, which means your volume is also dependent upon base-layer fader movements, you can have sub-mixes whose pans follow main, but whose relative amplitude levels are independent of the main mix.
It would actually be fantastic to have that capability on dLive as well. Otherwise you have to also add pan automation to sub-mixes/peripheral space mixes, which is kind of a pain.
Okay, I don’t know all the consoles. there are, of course, differences.
you would probably only need one manufacturer if all consoles were the same. :wink:
but most of the consoles are the same as I used to write.
Translated with DeepL Translate: The world's most accurate translator
to clarify something on here…
for monitors(IEM) this would be a PITA
for the moment I think it is ok like it is
if we “really” want this feature we need it switchable and have to discuss the implementation…
DiGiCo SD does it. ‘follow Master L-R pan’ as well as ‘L-R invert’ for all Stereo auxes and groups. Should be added to further dLive firmware updates.
@ Steffen R, I agree completely. You would absolutely not want this for monitors, but it does make mixing peripherals, cohesively, a LOT easier. …and for that reason, you would definitely, definitely, want to be able to toggle this on a per-buss basis!
Guma: You can invert L-R on a stereo channel on dLive. “Under Preamp” and “Stereo Image” there is several options such as R-L, Mono, L-L or R-R etc. Also the possibility to change the width. But the width is only global. (not per aux/mix based)
