T-112 usb files to T-80
Hello all, this is the first time I’ve been to this website and forum. I have a question that I’d like to know if anyone has the answer to.
I have a T-112 and I saved a show to a USB flashdrive. What will happen when I plug it into a t-80? What will the T-80 do to my channel layout?
I normally use the board with the first 12 faders being 1-12, and the second (12) layer being ch 13-24 and the third layer being 25-32. Then I use the the first layer of 8 channels in the middle for 33-40, 41-48, 49-56. I did a show for a band that used the first 2 layers (ch 1-12 and 13-18, and then they used the first layer 33-37. Everything else as split up as efx sends and returns. So, how will that come up? anyone have an idea? I have a friend who’s going to need to know before he gets to the gig what’s going to happen hen he takes my show file of his band to another sound companies T-80. Any suggestions by actual experience would be great. Thanks![8]
Load your show into editor in offline mode and set editor up with the T80 as the surface. Then bring up the surface window. I think you will need to then rearrange the surface layout to suit your needs. Resave the show back to USB.
Cheers
Richard Howey
Audio Dynamite Ltd
