Hi All,
Frequent SQ5 user, first time poster here.
I recently ran into an issue and today figured out what exactly was happening, but not sure if I’ve ran into a bug or feature change in the firmware.
I run a show where I’ve done some “trickery” to achieve a goal otherwise not possible on the SQ mixers (as far as my knowledge goes). I needed to send my solo bus into my “tech-mix” (just band-talkbacks and some click). I did this by routing PAFL to the mixers A+B outputs, jack jumper cables to ST2 in, and set ST2 as external input on that mix.
Achieve the goal for my backline tech of having a full mix + tech utilities, whilst also fulfilling my needs of having the PAFL on my pack (we share the same IEM transmitter).
Next bit of the trick is that I have a channel for my TB that goes to the band’s IEM’s and have it send to the Tech-mix via the mixers own talkback function, giving me the possibility to choose who I talk to (yes, an extra channel would’ve been easier, but I’m already maxed out on those)
Now that I’ve giving y’all the context, let’s talk about the weird issue I ran into. The moment I pressed the talk button on the desk, my backline tech mentioned he “didn’t hear the music anymore”. I’ll fast forward to today when I did some troubleshooting. Apparently when the talk button is engaged, it overrides/mutes the external input on that mix.
Although I don’t remember last years tour with the same group exactly, me and him are both sure this wasn’t the case back then. I have update the mixers firmware since. I’m pretty sure I’ve check all possible settings in both the PAFL and Talkback menu, but can’t seem to find a setting affecting this.
I’d be happy to be pointed out that I missed it, but has anyone else experienced a similar issue. And do we know if this is a bug or just a feature I’m disagreeing with?
Thanks in advance for all your time!
Cheers,
Imro
