Hi guys,
Does anyone know what channel input the talkback mic comes through as? EG If I want to record it into a DAW as well as the other 24 inputs (QU24).
Hi guys,
The TB can’t be routed to an input channel, but if you have a spare mix or group, you can route it to one of those then assign that to one of the usb channels.
Do you want the TB mic to go the DAW just to slate the recording takes for identification ?
You should be able to use one of the stereo inputs with a mic plugged into the mono L in and get enough gain to hear the mic on a recording, you could add some make up on that channel using the comp insert.
