Talkback Mic Setup
Would be great to have a versatile Talkback Mic Setup With the option to send the signal even to headphones outputs.
Here’s an advice until your request is realized.
Simply use a free input channel for talkback to your up to 7 output channels.
You could also assign your headphones to these channels and then hear the talkback there.
This approach has the great advantage that you can also use gate, EQ, and comp for your talkback.
I often use it this way on my consoles, too.
If it’s not that, what is the suggestion really suggesting? The original post is unclear to me.
It’s possible that I completely misunderstand you, but usually consoles operated by a sound engineer have a dedicated talkback function.
Yes, for sure. Maybe @Emi is suggesting a hardware input dedicated for talkback, like on the SQ:
I realize I was simply thinking about firmware only changes, and therefore could not get my head around what could be done.
