Talkback to output
I would like the function to assign a talkback group to a physical output directly, rather than sacrificing a mixbus.
this would be helpfull if you want the talkback somewhere externally. for example from the FOH system to the MON system and vice versa.
of course this is possible now by assigning a dedicated mixbus and route that mixbus to the desired output.
however if your low on mixbusses (which, i am at the moment) this isn’t a desired option.
also it doesn’t seem hard to implement since no mixing is required to pass the sound of a single microphone to a output.
if you think about it, its nothing more than a switchable direct out.
I agree this would be a nice add. We’re dealing with some of the same stuff and one of the only thing that kind of broke when we added a second console (and mix rack) for monitors was talkback from FOH to stage and backstage. We’ve done it with two mono busses but it’d be nice even if for just talkback groups to be able to pass down a tie line.
I agree, this would be very helpful
