TCP Midi Driver
Has anyone tried to trigger QLab from a soft key on the GLD?
I have spent hours looking and just cant get QLab to capture a command. Or maybe I am barking completely up the wrong tree and the TCP Midi driver doesnt recieve midi it only sends.
Thanks in advance.
P
I’ve done this with an iLive successfully, but not with a GLD. It’s the same driver so I’d have thought it would work. What is the midi string you are sending? Which version of QLab are you using and which licenses?
I use the Midi Show Control Commands for GO, Seq+/-, and STOP ALL which, respectively, are;
F0 F7 00 02 10 01 F7
F0 F7 00 02 10 13 F7
F0 F7 00 02 10 14 F7
F0 F7 00 02 10 08 F7
I do this with the buttons on a PL-10 which works superbly.
Richard
Richard,
Thanks for your comments. I have made some progress, by more luck than judgment. So I am using the latest build of QLab and a pro audio license. QLab seems to do nothing with the commands you sent me when associated with a soft key. Although I know QLab is listening to the GLD because if I tell it to learn a command and then move a fader it works.
So my question is am I being an idiot? Quite possible… or is this a bug?
P
What Device ID do you have configured in QLab MIDI Controls preferences? The strings I’ve used above are for Device ID 0. You could use Midi Monitor on your mac to see what, if any, command is received from the soft key press?
Richard
Richard,
Thanks again, So I have QLab set to use Device ID 0 as per your commands you sent, the funny thing is though that QLab wont even capture these commands or anything else I seem to put in as a custom command.
Attached are some screen grabs from Midi Monitor, I have to admit I know squat all about midi at this level so maybe they will mean more to you.
P
Ah, it does seem that the GLD might be doing something slightly odd with the command. I’ve attached what I get from an iLive which is only seen as one SysEx entry by Midi Monitor. I’ve also noted that the iLive software reformats the string when entered to be, for example, F0,F7,00,02,10,01,F7 i.e. it adds the commas. I don’t have a GLD to try it on myself but it may be worth trying. One random thing to try is to change the Device ID to 1 in QLab and the Go string to F0 F7 01 02 10 01 F7. This is just a wild idea based on a fault with another device I’ve seen before.
Failing this I suspect there may be an issue with the GLD and how it sends custom midi strings, best raise it with A&H support.
Richard
MIDI_Grab.tiff (32.7 KB)
As another thought try a “Musical” midi command. I often use 9C,50,75 on the Panic all (but should work for any command) command. You’ll need to turn on Use “Musical” MIDI controls in Qlab and set the channel to 13 hit capture for the relavent command and see if it picks anything up, and then works or not.
Richard
Richard,
Thanks for all your advice. Okay so it seems as you say that there is a bug using SysEx commands as custom midi commands on the GLD, yes it reformats on the GLD also to add the commas.
By using your suggestion of the musical midi note I have now managed to get this resolved and triggering my two QLab boxes perfectly!
Thanks so much for your help on this and guess I should log a call with A&H to get this “bug” looked into as I am sure down the road others will have the same issues I have.
P
Not a problem, glad to help! I’d be intrigued to hear if this is a GLD bug, I know enough about this stuff to get by, but it would be good to either confirm my thoughts or learn a bit more.
Richard
Ticket has been logged with A&H so lets see if they agree its a bug or if I was just being an idiot. My supplier seemed to agree it looked like a software bug.
P
Okay so A&H have come back to me and said the above commands are incorrect SysEx messages. They should read:
F0 7F 00 02 10 01 F7
F0 7F 00 02 10 13 F7
F0 7F 00 02 10 14 F7
F0 7F 00 02 10 08 F7
Notice the second section is 7F not F7 as per above as F7 indicates the end of a command.
P
Damn it! That’s what I originally ment the strings to say, and what I use, just a typo in my post above! Oh well I obviously need to check my typing more carefully!
Richard
Haha no problem at all! At least we have a post here for others to find now with information on using Qlab and the TCP driver :slight_smile:
