TCP protocol spec
This document
https://www.allen-heath.com/media/AH-External-control.pdf
says
“All Allen & Heath digital mixing systems are controllable over an Ethernet network. A TCP protocol spec document is available for each product line at www.allen-heath.com and details the string format, set of messages and TCP port to be used.”
Has anyone found such a document for SQ?
I’m desperate to have more control than is available via the midi implementation.
I assume you have seen the TCP MIDI documentation…
https://www.allen-heath.com/media/SQ-MIDI-Protocol-Issue5.pdf
Yes. I need to control more things than the midi implementation let’s me. Essentially as much as the Mixpad and Mixing station apps can access.
