hello,
When I work with my q24, it says that the Temprature of the Dac is 83 Celsius. The Cpu bored is 21.
iS it ok?
Not sure how “precise” the displayed DAC temperature is. When I switch on my console it reads about 60 degrees, maybe an offset or totally wrong scaling. I just ignore it and mounted a small silent fan beneath my desc (to calm my paranoia)…
The CPU temperature reading seems ok, at least it matches with other thermometers.
Thanks for the info. Just rechecked and understood that the displayed minimum temperature may be true but originates from the initial second the console switched on (23 degrees actually). Reaching the info dialog I saw the display crossing the 40 degrees margin, still rising. So, when I observed that 60 degrees I probably was a little too slow…
When I ran 3x QU16 side by side (for a festival a year ago) in a hot white Marquee, mid summer, the DAC temperatures went to from memory, 69 with the centre QU being 71.
I asked A & H before attempting to do this about overheating and they assured me all should be well.
In fact from memory I thought they said every QU was tested (turned on) for 3 days before being packed and dispatched.
Nicola,
I checked all the things you recommended and didn’t find anything. The temp is still above 80 degree. What do I do next?
What is displayed as min temperature? That one always equals ambient temperature on my desk.
Is your desk inside a case or free standing? Also obey that air inlet is underneath the desk (that’s where I’ve placed my fan) so that area needs to be free (not qualified as a store for blankets or similar).
