The Lnk indicator not on no network
was working now not is this broken??? I have used this feature a few times I sure hope is not broken!!
ok this weird it started working again I do not understand, its not the settings at all it actually stopped connecting to any network device I have 2 routers when one stopped seeing it the other did to when I swapped cables and the screen said IP with nothing after it. 1st time I ever seen this.
DHCP was on I also tried to do manually just to make sure, now its working and I’m leaving it connected. I move the cable around I do not see any intermittent connect. This is a less then year old mixer in mint shape
