This is on a qu-16 I am greener then a dollar bill mute group problems
I am trying to use mute groups. I have figured out how to set the group except we have the mix 5-6 set to feed to a computer. When I hit that group the mix 5-6 will mute on button above the master .
Apologies if, as a non-native English speaker, I am misunderstanding you, but I do not see a problem here.
It is absolutely correct that if you press the Mute button above the master of your Mix 5-6, that mix will be muted (the button will remain steadily lit).
However, this has nothing to do with a Mute Group to which you may have assigned Mix 5-6.
If you were to mute the mix via a Mute Group, the Mute button above the Master fader would be flashing.
Ok now I know what to ask. How to unassign from the mute groups the mix 5-6. In all the toggles for the mute groups I could not find the switch.
