Three outputs on QU 16
Hello,
is there a possibility to get three outputs (L,R,M) out of a QU16 console? My current console is a MIXWizard with L,R, M output. I only want to have beside of LR a further output for another room, which has the same mix like LR.
Thanks in advance and BR,
Skeelo :slight_smile:
IOPatch, surface, Alt out, LR, done
God luck !
Giga
Thanks Giga,
but how can I adjust the volume for Alt out independent of LR?
Thanks again :wink:
There’s a dedicated control nob for this.
@Skeelo, the Alt Out output has its own volume pot located just below the headphone volume pot on the upper right hand side of the console.
You can also use any of the mono outputs of the Qu16 (1-4). Select the mix, bring up all faders on that mix to unity, make sure every channel is POST fade, and then that mix should track exactly the same as your FOH mix. You can then use that mix’s master fader to adjust volume to that separate room. I prefer this method to using Alt Out because there is processing available on the mix output (EQ, Delay, etc.) that can come in handy when needed.
