touch screen restart By itself !!
My ilive t112 touch screen restart By itself
Has anyone ever seen me like this problem ?
Have Solution ? Thank you very much
humlivehouse Live sound system service company in Thailand
strange could you describe:
do you plug in the power and it starts - while the power button is off ?
or does it restart while it is on ? then it must be a “serious” problem and you better call your service (importing company in thailand).
cheers
dave
allen&heath iLive-144 /idr 10 / idr 48 /dante (i want midi in dante!)
A couple of days ago I reset the times on our units (mixrack, surface and touchscreen) so they would all read the same time for logging purposes. After doing that, the touchscreen will restart.
Kris
Indiana, USA
I had that happen with an ip address conflict. After we fixed the router it never happened again. For some reason the router decided to assign an ip address the same as the console…never did figure out why it did that. We just reset the configuration and moved the assignable ip addresses way up high and everything worked right.
112T/IDR48/IDR16
Having the same issue with an ILive144/IDR10 1.82
Since a couple of weeks it happend 4 or 5 times - without touching anything the TS just reboots by itself.
The only pattern is that it happens ca. half an hour after booting up the system - afterwards it runs fine so far.
Any hints appreciated.
Greetings,
Walter
Hi
HAd same Probleme last Fryday and today: Setup T112 iDR48 Monitor T112 Idr 32 FOH both with DANTE. Started up after lets say 30 Minuts both desks crashed, and restarted . LAst FRyday show without problems. Today stabel at the moment. Firmware 1.82.
Any ideas?
Flavio
Hi Sound/Giorgiomotore
Can you first please update your firmware to v1.83 and see if the issue still remains?
Regards
Sam A&H
