Transferring files from a Qu16 to the new Qu6d
Is it possible to transfer files from a Qu16 to a Qu6d?
What kind of files? Shows? Scenes?
These are not compatible.
Thanks Steffen, I didn’t look like it but I thought I would check. Thank you for you expert advice.
I believe you can load the scenes on the old board, connect Mixing Station, than use that to push as much as possible to the new board. It probably won’t be perfect but it should give you a good starting position.
